AMX Introduces SVSI N4321D Audio Transceivers with Dante and AES67
June 13, 2023
Feature-rich and Cost-effective Audio-over-IP Solution Supports Most Popular Audio Networking Protocols
InfoComm (Booth 4443) - ORLANDO — HARMAN Professional Solutions, the global leader in audio, video, lighting and control, today announced its new AMX SVSI N4321D Audio Transceivers with Dante and AES67.
These Transceivers are ideal for corporate applications, colleges and universities, casinos, convention and entertainment centers, or anyone needing robust Dante, AES67, or PCM networked audio over IP and analog transcoding at an affordable price point.
The N4321D connects independent IP and analog audio networks and supports balanced and unbalanced analog audio. Whether the project requires converting from PCM to Dante, Dante to analog, analog to AES67, or nearly any other combination of these technologies, these transceivers drastically simplify networked audio integration.
Perfect for point-to-point or point-to-multi-point audio delivery, the N4321D provides audio matrix switching and distribution using the same control options as SVSI's Networked AV video switching and distribution solution. Additionally, an open API makes it compatible with any AMX or third-party controller on the market.
With two auto-sensing gigabit Ethernet ports, units can also be used to bridge low-latency multi-channel audio between separate networks. One Ethernet port is PoE for use with a PoE switch, eliminating the need for an external power supply.
“The N4321D is a product we’ve been working to bring to the market for some time because there are so many applications for powerful audio transcoding and integrated Dante and AES67 support,” said Kyle Barron, Networked AV Product Manager, HARMAN Professional Solutions. “This product also underlines our AMX commitment to simplify interoperability in projects – whether the install includes other AMX products or not, we want our products to be able to first and foremost be an effective independent solution for the need or requirement.”
HIGHLIGHTS:
  • SIMPLIFED INTEROPERABILITY
    Support for Dante, AES67, streaming PCM and analog simplifies interoperability between SVSI and other IP audio networks. Analog audio ports streamline input and output of two-channel balanced or unbalanced audio.
  • VERSATILE INSTALLATION OPTIONS
    No matter your application, requirement, or budget, the N4321D will be ideal with the choice of box or card form factors and PoE to ease mounting behind a display, under a table, or in a rack.
  • LOW-COST EXPANSION OPTION
    The N4321D is perfect for applications that only require a low-cost audio encoding or decoding solution. Additionally, PoE power requires a single network cable and no additional power supply to maximize cost savings.
  • EASY TO CONFIGURE AND MANAGE
    With the onboard web configurator, the N4321D can be configured and managed directly, or with the SVSI SW ecosystem, including N-Able and N-Command.
  • OPEN DIRECT-CONTROL API
    An open API makes it possible for any control system or application to control N4321D transceivers. Whether part of a larger HARMAN Professional installation or the only AMX product in an install with products from other manufacturers, the open API allows seamless integration.
Additional Details
For complete product details and specifications, please visit:
