March 19, 2025
NORTHRIDGE, Calif. — HARMAN Professional Solutions, the global leader in audio, video, control, and lighting systems, today announced the launch of its Martin Exterior Projection Pro Compact, a breakthrough outdoor image projector designed to inspire captivating creativity and versatility across a diverse range of architectural, façade, and landscape applications.
Featuring a modular design with 11 configurable options and up to four layers of effects, including precise façade framing, the fixture offers a broad spectrum of creative possibilities while minimizing complexity and cost. Its compact footprint and lightweight design facilitate pole mounting and seamless integration into various setups, delivering multiple application possibilities. The fixture’s sleek, professional appearance ensures it blends effortlessly into any environment.
The built-in zoom system enables precision adjustment of the projection angle from 15° to 45°, supported by an ultra-efficient optical system that consistently delivers 4,400 lumens across the entire zoom range. Engineered for maximum energy efficiency, the fixture includes a dedicated hibernation power mode, activated through the DMX control channel, significantly reducing power consumption when not in use.
Empowering users with control over multiple dynamic effects—including zoom, focus, colors, gobos, and animations—the Exterior Projection Pro Compact motivates the most creative applications. Using the optional framing module, the projected image can be framed to precisely match the façade. Smart controls feature a magnetic switch, DMX, RDM, and stand-alone programming via Martin Companion, ensuring straightforward configuration and programming.
Engineered to meet stringent environmental standards, the fixture reduces its carbon footprint through its efficient optical system, FSC-certified packaging, and full repairability. Designed for permanent outdoor installations, it is fully outdoor-rated to withstand the harshest environmental conditions and is backed by Martin’s full, 5-year warranty.
With its modular design, compact form factor, and state-of-the-art features, the fixture is an incredibly advanced and cost-effective solution. Ideal for architectural lighting designers, architects, system integrators, and electrical contractors, it offers unmatched performance, versatility, and user-friendly operation.
“We couldn’t be prouder to introduce our newest addition to our Exterior Pro range of Martin architectural lighting solutions,” said Robert Svensson, Product Manager of Martin Architectural Lighting. “We designed Exterior Projection Pro Compact to empower lighting designers to fully realize their creative ambitions without the headache of excessive complexity or cost. That’s why we built it - to deliver exceptional outdoor image projection performance and flexibility but to also be incredibly efficient. We are looking forward to seeing the works of art that are inspired from its designs.”
FEATURE HIGHLIGHTS:
VERSATILE CONFIGURATION v The Exterior Projection Pro Compact’s accessory effect modules adapt to the unique needs of each application, providing a cost-efficient and lightweight solution.
PRECISE BEAM CONTROL WITH FLAT FIELD
The built-in zoom system enables precise adjustment of the 15° to 45° projection angle, ensuring easy positioning and optimal surface coverage. The projected image maintains a flat field with high contrast.
COMPACT AND ATTRACTIVE DESIGN
With its compact footprint and low weight, the fixture can be pole-mounted and integrated into various setups, delivering multiple applications.
HIGHLY-EFFICIENT OPTICAL SYSTEM
The efficient optical system ensures full lumen maintenance across the zoom range. The optional framing module allows the projected image to be framed to precisely match the façade.
SMART CONTROL OPTIONS
Magnetic switch, DMX, RDM, and stand-alone programming via Martin Companion offer straightforward configuration and programming. The fixture also features a dedicated hibernation power mode, activated via the DMX control channel, significantly reducing power consumption when inactive.
DESIGNED FOR REAL-WORLD CONDITIONS
Engineered to meet stringent environmental standards, the fixture reduces its carbon footprint through its efficient optical system, FSC-certified packaging, and full repairability. It is fully outdoor-rated to withstand harsh environmental conditions and is backed by Martin’s full 5-year warranty.
ADDITIONAL DETAILS & SPECIFICATIONS:
