Houses of worship and education facilities often face unique challenges in finding the right professional-grade, portable sound system to support their select needs and requirements. High performance is often the most important factor, as it should be, to ensure these systems sound their very best at any volume and are equally loud, clear, and intelligible. Whether broadcasting announcements, delivering presentations, supporting performances, or playing music, the right system must also be durable, reliable, and easy to use.
The JBL EON ONE Compact packs a professional speaker, a full-featured, 4-channel mixer and Bluetooth control into our most compact battery-powered PA, weighing in at just 17.6 pounds.
With more and more gatherings and classes opting to move out of traditional indoor spaces, having a solution that is ready at a moment’s notice, regardless of pluggable wall power availability, makes true system portability increasingly popular. The JBL EON ONE Compact All-in-One Rechargeable Portable PA meets all of these needs and handily exceeds them.
Let’s take a closer look at the unmatched flexibility and unique advantages that EON ONE Compact creates for houses of worship and educational facilities.
Spectacular, Space-Filling Sound Indoors and Out
Whether you’ve taken your class into the garden or are onstage in the auditorium, EON ONE Compact ensures your audience can hear every word and musical nuance in perfect clarity. Its 8-inch woofer delivers deep, uncompressed bass down to 37.5 Hz. and with the highest overall volume in its class at 112 decibels, the system truly sings across its entire range, even at high output levels.
EON ONE Compact is perfect for weddings and other celebrations whether you want to have great sound for toasts and dancing under the night sky or you decide to run off to a remote location, 12 hours of uninterrupted battery life ensure an epic event, wherever you hold it.
Embracing the Transformative Power of the Outdoors
Having the flexibility to move your meetings and gatherings outdoors for fresh air and more space often increases engagement and collaboration. EON ONE Compact is ideal for quick moves outside because it is both ergonomic, easy to carry and lightweight. At just 17.6 pounds (8 kg.), it can typically be carried with one hand and moved on the fly whenever its time to ditch the desks for some open sky.
Incredibly Simplified Pro Mixer Control
When it comes to controlling your sound, the onboard pro mixer offers super simple control over the most used adjustment areas – loudspeaker, amp, mixer, and effects. For lectures and readings when you want to shape the sound to best support the presenter, EON ONE Compact includes a 4-channel digital mixer with dbx and Lexicon-inspired professional effects including 4-band EQ, reverb, chorus and delay.
Watch this overview to get to know the key benefits and features of that ensure EON ONE Compact is the ideal all-in-one rechargeable portable PA for a wide range of applications.
Advanced App Control for Next-Level Adjustments, Wherever You Are
When your EON ONE Compact is ready to support your outdoor service or singalong, it can be incredibly freeing to have the ability to make on-the-fly sound adjustments from wherever you are, whether next to the presenter, out in the audience, or across the lawn.
The free EON ONE Compact Connect App, available for Android and iOS puts you in total control of all your EON ONE Compact functions. It also allows you to stream Bluetooth audio to up to four EON ONE Compact speakers and puts you in the driver’s seat for controlling EON ONE Compact’s four-channel digital mixer. More robust EQ control, Lexicon effects management, saving and recalling presets and much more make the App a huge convenience.
12 Hours of Anytime, Anywhere Battery-Powered Freedom
EON ONE Compact’s 12-hour battery life further empowers the ability to take gatherings and talks wherever you want to take them – indoors, outdoors, on a mountain, in the desert, up in the air, or out on the water – your imagination is the only limitation on where EON ONE Compact can best serve you. Want to play, sing, stream, and present even longer? Multiply your battery life exponentially with additional batteries that swap out in seconds with no tools necessary.
The powerful EON ONE Compact Connect App allows you to stream Bluetooth audio to up to four EON ONE Compact speakers, empowers control over EON ONE Compact’s four-channel digital mixer, and much more.
When it’s time to recharge, these batteries can be quick-charged in just 2.5 hours – you can even charge while the system is in use.
Duck, Duck… GO!
Whether hosting preschool playground games or an adult scavenger hunt, everyone will appreciate EON ONE Compact’s ducking feature, which automatically lowers background music volume anytime you speak to ensure your audience hears every last word, loud and clear. So crank up the music and when you need to temporarily share a message or announcement, everyone will hear it and the fun can immediately start up again.
Class-Leading Connectivity
With more inputs than any system in its class, no matter what performance, play, or presentation you want to support, go ahead and plug in as EON ONE Compact supports the most often utilized input and output connections.
No matter where you want to play, present, or perform, EON ONE Compact makes it easy to setup quickly and sound incredible.
These include two XLR/TRS combo jacks, one 1/4-inch hi-Z guitar input and one 1/8-inch aux input to connect microphones, line-level instruments and audio playback sources, and more.
Plus, a 1/4-inch passthrough offers the ability to expand with additional EON ONE Compact units. And the built-in headphone jack offers private rehearsal or the ability to dial-in presets before performances. Two high-power USB 3.0 ports offer high-speed charging of tablets, phones and select DJ devices.
When it comes to creating outdoor anytime, anywhere houses of worship and education spaces, JBL EON ONE Compact has the power, performance, reliability, and ease of use to support just about any indoor or outdoor application or need.
EXPLORE FURTHER
Dive into our support resources to get complete details, specifications, and more:
- Details:
- Videos
- Subscribe:
- Sign up to receive the latest JBL product updates via email
- Get notified of our newest videos to debut on the JBL YouTube channel
READY TO TALK TO A SOLUTIONS EXPERT
If you are interested in JBL Performance Audio, or other professional audio support, we have a solutions expert ready to assist you. To locate a representative near you, please visit our WORLDWIDE LOCATOR.
