Designing commercial ceiling speaker systems can be challenging. However, ensuring you have the right plan, tools, expertise, and solutions in place can make all the difference in creating the ideal listening experience.
To assist integrators, designers, and consultants navigate the process of designing commercial in-ceiling audio projects, we talked with Ashish Barje. Ashish is Product Manager for Commercial Loudspeakers at JBL Professional and HARMAN Professional Solutions.
With deep tenure managing the development of some of the world’s top commercial ceiling speaker systems, Ashish shares key questions and essential considerations that can be helpful to integrators in better understanding client needs when designing commercial ceiling speaker systems.
We also asked Ashish to share a recommended commercial ceiling speaker that’s both high-performing and versatile enough to meet a variety of diverse applications. Read on to discover what we found out.
Asking the Right Questions
Q: Ashish, thanks for joining us. In your experience, which questions will help integrators best understand a client’s goals?
A: Thanks for having me. I recommend asking a variety of questions to envision the client’s needs:
- What is the room’s primary use? This will help dictate your system design. A background music system in a restaurant, an audio system in a classroom, and a high-energy setup in a fitness club or bar have very different requirements. The application defines speaker size, model, and quantity.
- What Sound Pressure Level (SPL) is needed at the listening position? Background music applications, like those common in cafes or retail stores, typically require much lower SPL than applications where speech intelligibility is important or where ambient sound levels are higher, such as in houses of worship, convention centers, or airports.
- Will the space be used for alternative applications? This is also a worthy consideration such as a boardroom that might be used to watch the big game that might require more headroom or other considerations to ensure the room sounds great no matter what it’s being used for.
- What budget parameters do we have to work with? The client’s budget will have a big impact on the design such as what performance levels can be utilized, how many listening spaces can be served, and other budget-impacting questions.
Ceiling Architecture and Sound Dispersion
Q: How do ceilings impact sound dispersion and coverage?
A: Flat ceilings generally fall into two categories: tile-grid or hard, thick ceilings. In both cases, ceiling height and desired SPL dictate speaker count and model choice. Higher ceilings reduce SPL and speech intelligibility at listener level.
For taller ceilings between 18′ and 24′, specialty speakers like JBL’s Control 47HC high-ceiling model offers narrow dispersion. This delivers focused, efficient coverage and clear speech. In open-ceiling designs with exposed HVAC ducts and infrastructure, surface-mount or pendant speakers work best. You can hang them at optimal heights to achieve the required coverage.
Installation Challenges
Q: What challenges do installers typically face when designing commercial ceiling speaker systems and how can certain speaker features solve them?
A: Installers will typically encounter issues in three phases:
- Phase 1: Pre-installation – Decide between blind-mount speakers or pre-installed backcans. JBL offers both. With backcans, install housing and cabling during construction, then fit the speakers after ceiling work finishes. This prevents dust and paint buildup. Speakers with integrated enclosures can be installed into a finished ceiling, offering more flexibility for repositioning. Shallow plenum spaces may require low-profile speaker models; JBL has several to choose from. Accessories like tile rails, tile bridges, C-rings, and mud rings support various ceiling types.
- Phase 2: Speaker Installation – Installers balance many tasks from a ladder. Features like sturdy, reliable dog-ears that work with a wide range of ceiling thicknesses, options for top- or side-cable entry, and simple-to-install magnetic grilles ease this process.
- Phase 3: Post-installation Tuning – If ceiling speakers create hotspots or gaps, tuning can be tricky and unreliable. Inconsistent sound leads to dissatisfaction. JBL’s ceiling speakers use proprietary technologies for exceptional pattern control and uniform coverage. Reduced on-axis hotspots and off-axis cold spots ensure clear, pleasant sound across the listening area.
Manufacturer Considerations
Q: What should integrators consider when selecting a ceiling speaker manufacturer?
A: Reputable and highly-regarded ceiling speaker manufacturers, like JBL Professional, should be able to support your projects in a variety of ways but specifically with top-performing products, industry expertise, technical support, and on-demand and in-person training and certifications. At a minimum, you should be able to answer yes to these questions when considering a manufacturer for your projects:
- Do they offer a broad range of models to fit performance requirements and budgets?
- Do they offer models that include compliance with life-safety standards such as EN54-24 or UL1480?
- Do they offer a variety of system-design tools to calculate speaker quantity and coverage?
Spotlight Solution:
JBL Control 400 Enhanced Coverage Series Ceiling Speakers featuring CRBI™ Technology
Understanding CRBI™ Technology
Q: What is JBL’s Coplanar Radiation Boundary Integrator (CRBI™) technology and how does it improve off-axis performance?
Get detailed specifications, videos, and more to explore the JBL Control 400 Enhanced Coverage Series Ceiling Speakers.
A: CRBI™ is a pattern control technology we’ve developed with learnings from our existing Radiation Boundary Integrator® (RBI™) technology. While models like the JBL Control 40 series use a three-dimensional RBI and are able to deliver constant directivity, the Coplanar RBI in the Control 400 Enhanced Coverage series is able to deliver nearly as consistent coverage at a lower cost.
Feedback-Driven Design
Q: What role did integrator and consultant feedback play in introducing CRBI™ into the JBL Control 400 Enhanced Coverage Series?
A: RBI™ technology, offered in the Control 40 Series has been very well received in the market. Many integrators and consultants were interested in integrating the same technology in our more affordable ranges of products. The flat design, or Coplanar Radiation Boundary Integrator, allows us to provide many of the advantages of our premium, conical RBI solution at a lower cost.
Supporting the Integrator
Q: How do Control 400 Enhanced Coverage Series installation-friendly features simplify integrators’ work?
Learn more about CRBI™ coverage technology in the Control 400 Enhanced Coverage Series Speakers Overview Video.
A: We designed the lineup to improve installation repeatability and safety while reducing installation time for integrators. Key installer-friendly enhancements include:
- All speakers in the Control 400 Enhanced Coverage Series feature a built-in 70V/100V multitap transformer. This simplifies product choice for the integrator.
- With six different speaker models to choose from, integrators can design more freely and have more driver sizes and enclosure depths to ensure more versatility.
- Top- and side-exit cable entry options let integrators easily modify speakers according to the needs of the install.
- The captive dogear design is extremely reliable and works with a variety of ceiling thicknesses to widen application options.
- A full-face, magnetic grille offers a sleek and refined look giving integrators more options to elegantly blend into a variety of room designs. There are also square and black accessory grille options for every model.
Project Savings Possibilities
Q: How can the improved coverage of the CRBI™ design lead to project savings?
A: CRBI™ technology delivers extremely consistent coverage of the listening space. Sound character of the speaker remains consistent, clear, and pleasant, even in off-axis coverage areas. Since a speaker with CRBI delivers a more consistent sound throughout the entire beamwidth compared to normal ceiling speakers, fewer speakers are needed to cover the same space, which typically leads to a reduction of system cost without sacrificing performance.
Wrapping Up & Exploring Further
Check out this in-depth discussion that shares the story behind the Control 400 Enhanced Coverage Series.
By asking the right questions of clients and putting the ideal plan, design, and solutions like the JBL Control 400 Enhanced Coverage Series in place, integrators can design highly successful commercial ceiling speaker systems that elevate the listening space and ensure consistent coverage and reliable performance.
Here are some additional resources to support your research and purchasing journey when designing commercial ceiling speaker systems. We look forward to learning more about how we can better support your needs in the future.
Details & Specifications:
- JBL Control 400 Enhanced Coverage Series Ceiling Speakers & Video
- JBL Installed Loudspeaker Portfolio
- JBL System Design Tools and Software
- JBL Videos
- JBL Case Studies
- JBL Training Resources
- Anytime Help Center
Connect with Us:
- Sign up to receive our latest updates via email
- Get notified of our latest videos to debut on YouTube
READY TO TALK TO A SOLUTIONS EXPERT?
We’d love to discuss your projects and ideas. To locate a representative near you, please visit our WORLDWIDE LOCATOR.
