When it comes to selecting the best moving head lights for outdoor festivals, designers and rental houses face a tough challenge. They have to find creative ways to balance brightness, durability, and flexibility against unpredictable weather, long runtimes, and the need for maximum visual impact.
To help us understand how to meet these challenges, we spoke with Oniel Gibson, Senior Manager of Technical Resources for Martin Professional and HARMAN Professional Solutions. Oniel shared key considerations for finding the right moving heads that balance outdoor-friendly performance and reliability. He also highlighted game-changing options like the Martin MAC Viper XIP. Martin’s Performance Lighting Product Manager, Henrik Kristensen, also contributed significantly to this discussion.
Challenges in Selecting the Best Moving Head Lights for Outdoor Festivals
Q: When it comes to selecting festival moving heads, what are some of the main challenges?
Norway’s Palmesus Festival offered a variety of challenges for designers because of its beachside location and unpredictable weather. Watch to learn more.
A: Festivals often run day and night. A fixture has to be powerful enough to cut through daylight, but also tough enough to withstand the elements. When I started in this industry in 1998, I was surprised in the options available for intelligent outdoor lighting. But one theme stood out: customers often needed multiple accessories just to protect their investments. Companies tried to design weatherproof lights, but most came with trade-offs—extra weight, larger size, or lower output.
Q: How do environmental conditions impact fixture performance and reliability?
A: Heat is the number one issue in any lighting product. Rain, humidity, and dust all make it worse. Moisture causes fans to pull in dirt faster, which reduces airflow. Less airflow means the unit runs hotter—and that’s the fastest way to damage components. Output is another factor. Outdoors, fixtures get dirty much faster, and that buildup reduces brightness.
Balancing Fixture Trade-Offs
Q: What trade-offs must be considered when choosing between fully sealed outdoor fixtures and high-output indoor fixtures?
Heat, dust, and sand were all challenges that designers had to overcome selecting the right fixtures to perform at MDLBEAST Soundstorm Festival. Watch to see what fixtures they chose.
A: The main differences are size, weight, and output. Fully sealed units keep dirt and moisture out, but as internal heat rises, output drops. Servicing them also requires vacuum testing, torque-specific, and other specialized tools. On the other hand, high-powered indoor units deliver consistent output, but if you use them outdoors, they need more frequent maintenance.
Q: How important is flexibility when transitioning fixtures between indoor and outdoor festival stages?
A: At the end of the day, it’s all about ROI. Flexibility is critical. Years ago, customers used different lights for different situations. Over time, they realized they could get better ROI by reducing inventory to one or two versatile fixtures, instead of maintaining five or six specialized units.
Spotlight Solution:
Martin MAC Viper XIP: Ideal Weatherproof Fixture for Outdoor Festivals
Why the MAC Viper XIP Excels for Outdoor Festivals
Q: What makes the MAC Viper XIP particularly well-suited for outdoor festivals?
Check out what’s possible for your designs inside the Martin MAC Viper XIP Introduction and Product Overview video.
A: The MAC Viper XIP has a solid build and versatile output. It’s powerful enough for both large and small stages. Its airflow and filtration system keep dirt and dust out. In wet conditions, the water abatement system channels moisture away from vital components. Because the unit can breathe, the optics stay clear of fog—so output stays crisp. And as a technical person, I really value how easy it is to service and maintain. As a technical person at heart, I value ease of service and maintenance.
Q: How does XIP weatherproofing technology work and why is it a breakthrough?
A: Unlike fully sealed enclosures, XIP uses smart ingress protection. It allows airflow while still protecting against water and dust. That means the fixture stays cool and performs at its best—without the weight and bulk of sealed units. The result is full-featured performances, rain or shine, without compromising output, noise, or serviceability. It’s a game-changer for festivals and touring productions.”
Explore how Martin XIP weatherproofing technology works. Learn how it allows fixtures to to be used in any weather without the added burden of increased weight, size, or lower output. Then dive further here.
What Sets the MAC Viper XIP Apart from Other Fixtures
Q: How does MAC Viper XIP avoid the common drawbacks of fully sealed fixtures?
A: The MAC Viper XIP sidesteps typical trade-offs with a lightweight design and a powerful light engine. At just 81 pounds, it’s much lighter than many sealed outdoor fixtures, making it easier to rig and transport. Its 28,000-lumen output rivals much larger units. And because it’s not fully sealed, it avoids the thermal buildup that can reduce output over time. The result is a fixture that’s bright, nimble, and festival-ready.”
Rental House and Production Advantages
Q: What advantages does the MAC Viper XIP offer rental houses and production teams?
A: For rental houses, MAC Viper XIP delivers a rare trifecta: high performance, low maintenance, and logistical efficiency. Its XIP weatherproofing means fewer fixture swaps reducing downtime and labor costs. Maintenance is streamlined with features like NFC and the Martin Companion Mobile app and easy access to internal components. Plus, its indoor quiet operation and outdoor durability means rental inventory can be deployed across a wider range of gigs, maximizing ROI.
Real-World Success Stories
Q: Can you share some examples of XIP being used successfully in major outdoor festivals?
Lighting Designer Marius Flatnes shares what went into designing the Palmesus beachside festival utilizing the Martin MAC Viper XIP.
A: Since we launched XIP, we’ve seen many uses of it in festivals and outdoor events that supported LD needs to ensure reliability. Here are some examples:
- Palmesus Festival, Norway: MAC Viper XIP was specifically selected for the Palmesus Festival because of its unpredictable beachside location. See what the LDs who designed it had to say.
- MDLBEAST Soundstorm Festival, Saudi Arabia: At MDLBEAST, the fixtures performed impeccably even under huge desert dust and temperature swings. Watch the designers’ reaction.
WRAPUP & EXPLORE FURTHER
Outdoor festivals demand fixtures that deliver uncompromising output, withstand harsh conditions, and remain flexible enough for both indoor and outdoor use. The Martin MAC Viper XIP demonstrates how smart ingress protection and thoughtful design can overcome the traditional trade-offs of sealed outdoor fixtures. We invite you to explore further and connect with us to let us know how we can best support your projects.
Details & Specifications:
- Martin MAC Viper XIP Moving Head
- Exploring Martin XIP Weatherproofing Technology
- Solution Portfolio
- Videos
- Case Studies
- Insight Blogs
- Training
Subscribe:
- Sign up to receive our latest updates via email
- Get notified of our latest videos to debut on YouTube
Connect with Us
Ready to Talk to a Solutions Expert?
We’d love to discuss your projects and ideas. To locate a representative near you, please visit our WORLDWIDE LOCATOR.
