Introduction
Whether you’re a DJ, musician, fitness instructor, or corporate presenter, finding the right portable PA system for mobile professionals ensures elevated listening experiences and quick, seamless deployment.
We talked with Brandon Knudsen JBL Professional’s Senior Product Manager for Loudspeaker Systems to gain his expert insight. In this guide, Brandon shares what to look for when selecting ideal pro-grade point-source powered systems. He also shares how JBL’s PRX925 and PRX935 loudspeakers are smart options when it comes to optimizing the listening and management experience, no matter your application or skill level.
Understanding the Basics
Explore JBL’s portfolio of portable PA solutions – ideal for any space, application, or need.
Q: What defines a point-source powered loudspeaker system, and why is it ideal for mobile professionals?
A: Point-source or “point and shoot” powered loudspeakers pack amplification, DSP, and input/output functionality into one enclosure—just plug in, power up, and you’re ready to go. This streamlined approach slashes setup time, reduces gear count, and eliminates the learning curve of matching separate amps and crossovers. And the point-source or point and shoot aspect, is exactly that. You point the speaker where you want audio, and it shoots it there.
Q: How does a powered PA system differ from passive setups in terms of ease of use and performance reliability?
A: With powered PAs you never have to worry about pairing an amp to a speaker cabinet or routing external crossovers. The result is consistent sound quality and far fewer opportunities for failure on the road, as well as less stress on the overall package as the amplifier and transducer system are tuned specifically to each other.
Application-Specific Advice
Q: What should DJs, musicians, and mobile professionals look for when choosing a portable PA system?
A: You’ll want enough output to comfortably fill your typical crowd size, plus driver configurations that suit your content—larger woofers for deep bass in dance-music sets, or focused mid/high drivers for clear instructor cues. Onboard DSP tools like EQ presets, advanced feedback suppression (AFS), and limiter functions help you dial in great sound fast.
Q: How do venue size and audience type influence the choice of speaker configuration?
A: In smaller rooms, a single full-range enclosure can often do the job, keeping things simple and space-efficient. For mid-sized venues—like community centers or larger fitness studios—a combination of mains plus a subwoofer delivers a perfect stereo image with a well-balanced frequency response. Large halls or outdoor events typically call for multiple tops and subs, geometrically placed to achieve even coverage and avoid hot spots.
Learn more about JBL PRX900 Series next-gen woofer design.
Q: What are the most common mistakes mobile professionals make when setting up their PA systems, and how can they avoid them?
A: Speaker placement is generally the biggest mistake every professional makes. Knowing where your bass frequencies are accentuated helps control overactive low frequency, while keeping your speakers at proper distances away from each other helps preserve the stereo image while minimizing lobing and frequency cancellation.
Performance & Durability
Q: How does JBL ensure consistent audio quality across different volume levels and environments?
Check out the portfolio of JBL Portable PA video resources.
A: JBL’s Class-D amplifiers, precision-engineered drivers, and acoustically optimized DSP presets work together to maintain sonic integrity. The system dynamically adapts to prevent overload, so you get tight bass, detailed mids, and crisp highs no matter where you play.
Q: What should users look for when selecting durable, road-worthy portable PA systems? What kind of warranty should they look for?
A: Look for components housed in strong, lightweight cabinets that maximize acoustic performance and durability. JBL’s PRX900 Series cabinets are constructed from a polypropylene/talcum blend that’s optimized for rigidity. Additionally JBL PRX900 Series subwoofer enclosures and JBL PRX925/PRX935 loudspeakers are built from 18mm birch with optimized bracing. JBL cabinets also feature Duraflex coatings for superior durability.
Learn about the reliability of the JBL PRX900 Series and all JBL speakers.
Like every JBL product, PRX900 Series loudspeakers and subwoofers undergo an industry-leading 100-hour stress test of all components to ensure systems perform beyond expectations in real-world scenarios.
They’re so reliable that each speaker is backed with an unprecedented seven-year warranty.
Spotlight Solution:
JBL PRX925 & PRX935 Powered Loudspeakers
Product Differentiation
Q: What inspired the development of the PRX925 and PRX935, and how do they expand the versatility of the PRX900 Series?
A: The JBL PRX800 Series supported a dual-2 way and 3-way design, and as we built the PRX900 Series, we engineered some high-performing transducers that we felt could drastically improve over the PRX825/835. The PRX925 offers a dual-2 way design with two 15” woofers that extend frequency response so low, you can shake the walls without a subwoofer. PRX935 offers a balanced 3-way design perfect for installed or portable public address and house of worship applications. PRX935 adds a dedicated mid driver for crystal-clear vocals.
Explore the JBL PRX925 and PRX935 product walkthrough.
Q: How does the JBL Pro Connect App simplify system management of the PRX925, PRX935, PRX900 Series and other Pro Connect-enabled speakers?
A: The JBL Pro Connect App turns smartphones and tablets into full-featured system management consoles.
- Demo Mode – Tour the app’s capabilities without having to own or connect a Pro Connect-enabled speaker. Additionally, Demo Mode allows existing users the capability to configure and save system settings and presets without being connected to their speakers.
- Speaker Grouping and Renaming – Group speakers for mixing and rename channels for traditional channel strip functionality. Responsive portrait and landscape displays streamline operation.
- And much more…
Technical Deep Dive
Q: What are the practical implications of the PRX925’s dual-15″ two-way vs. the PRX935’s three-way single-15″ design?
A: PRX925’s dual woofers boost low-frequency extension for music-heavy gigs. PRX935’s three-way layout excels at intelligibility and clarity at any volume.
Dive into the JBL Pro Connect App Tech Talk.
Q: How does the birch cabinet construction enhance low-end response and durability compared to polypropylene enclosures?
A: Birch plywood is stiffer and less resonant than polypropylene. It offers tighter bass and better road resilience under heavy use and extreme conditions, with the sacrifice or trade-off of being considerably heavier than polypropylene.
Real-World Feedback
Q: What feedback have you received regarding the PRX925 and PRX935 loudspeakers?
A: Rental houses appreciate being able to recommend PRX925’s distortion-free bass to their customers. It’s a great option for significantly enhancing low-end in a variety of spaces. Corporate and House of Worship managers like PRX935’s mid driver that cuts through noise in larger spaces and halls. They keep presenters sounding crystal-clear.
Explore Further and Let’s Talk
Choosing the right portable PA systems for mobile professionals ensures less time troubleshooting and more time focusing your craft. Explore further below and let us know how we can best support you.
- PRX900 Series Details
- PRX925 Loudspeaker Details
- PRX935 Loudspeaker Details
- JBL Portable PA Solutions Portfolio
- JBL PRX900 Series Videos
- JBL Case Studies
- JBL Training Resources
- Anytime Help Center
Connect with Us:
- Sign up to receive our latest updates via email
- Get notified of our latest videos to debut on YouTube
Ready to Talk to a Solutions Expert?
We’d love to discuss your projects and ideas. To locate a representative near you, please visit our WORLDWIDE LOCATOR.
